Universal Air Suspension setup w/ Dakota Digital Height Controller.
Universal Air Suspension.com setup w/ Dakota Digital Height Controller. Never driven on. Just mounted and tested up and down clearance in my car (it was an Acura). It is basically brand new. This particular set up will raise and lower the front of the car to clear driveways and speed bumps. Also, comes with a spare set of airbags.
You will need to check with UAS to see what will be needed to get it to work on your specific car. The airbags are a universal fit for struts, so there shouldn't be issues with them. But you will need to get the brackets from UAS to be able to mount them in correctly.
Comes assembled and already tested for any leaks. I did all the hard stuff for you. All you need to do is run some basic electrical, mount the tank in the trunk (2 bolts), mount the valves (4 bolts) and change the springs out with the bags.
Includes:
1- Dakota Digital Height Controller (raise and lower with 3 memory presets at the touch of a button - displays tank and each air bag PSI)
4 – Aero Sport Strut Bags
4 - High Performance 1/2 Racing Valves
4 - Brackets
1 - Viair 380 (100% Duty, 200 PSI)
1 – 5 Gallon Black Stainless Air Tank
1 - Dual Needle Air Gauge
1 - Preset Pressure Switch
1 - Wiring Accessories to hookup Pressure Switch/Compressor
1 - Brass D.O.T. Fittings
1 - Safety Check Valve (Prevents car from dropping with Loss of air)
1 - Water Trap
3 - Toggle Switches
1 - D.O.T. Approved Airline
Costed me 1800.00 new. $1300.00 OBO plus shipping. All manuals and original boxes included. Selling because I sold my car.
You can email to quantex23 @ hotmail.com. thanks.
Includes:
4 - Brackets
1 - Water Trap
3 - Toggle Switches
