Drag Strip From the staging lanes to the finish line, this is the spot for on-track drag racing discussion.
Great Lakes Dragaway--PRO-FWD for 2008
Old Nov 19, 2007 | 04:11 PM
BEEYOND's Avatar
BEEYOND
Default Great Lakes Dragaway--PRO-FWD for 2008
If you guys haven't heard Great Lakes Dragaway in the WI/IL area will probably be including a PRO-FWD class for 2008. Quick16, Frantic 7, and 13-16sec classes will all remain the same....
PRO-FWD rules:
-4cy or 6cyl FWD
-Heads-Up (not bracket racing..where you dial in your time)...heads-up means go balls out and beat your opponent!!!
-one power adder
-no tube chassis
-any tire
This class will more then likely make it to the schedule of GLDW Import Wars for 2008.
check the dragstrip out if you haven't been there: www.greatlakesdragaway.com
Let me hear what you guys think of adding PRO-FWD for 2008???
Old Nov 23, 2007 | 10:58 PM
18crx's Avatar
18crx
stock booster
what about the low 11 to high 10 class.
