Compression Test
Old Oct 30, 2007 | 12:42 PM
Schwa's Avatar
Schwa
Schiggity
Default Compression Test
Just ran a compression test:
When dry all values were 190
When wet all values were 240-250
Is it normal for the values to be so different? and are these normal?
Old Oct 30, 2007 | 12:46 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
If all are relatively the same then its normal......Lets say 1, 2, 4 were 185 and 3 was 150....that would be a problem
Old Oct 30, 2007 | 12:49 PM
Schwa's Avatar
Schwa
Schiggity
Yea they were less than 5 off between all values. So almost exactly the same... just wasnt sure if there should be that much of a difference between the wet and dry test?
Old Oct 30, 2007 | 01:00 PM
F22B Prelude
Rachel Bilson
If the wet test is higher than the rings might be worn....are you burning oil?
Old Oct 30, 2007 | 02:28 PM
Schwa's Avatar
Schwa
Schiggity
yea i usually have to add a quart every month or so... I was told thats pretty normal for a prelude, but seems like a lot to me
