hatch with boosted gsr
the car i recently bought is runing a little rough and i just dont have the time to sit down and test everything... it idles a little wierd and the idle stays at 1500 when i am in neutral and when i come so a complete stop then the idle goes back to normal i need a little help and i think i have a misfire at idle....
So on initial start up it stays around 1500 rpm? Or just neutral in general? If it goes back down when you come to a complete stop, for some reason I want to say it's the idle air control valve.
Did the Greddy turbo kit come with atleast e-manage?
i am stil waiting on my honda data.. ok when i start my car is at 1500 rpms then when its at operating temp it idles normaly. then when iam driving around and i put the clutch the rpms stay at 1500 till i come to a complete stop... as i said in my other post it ran fine before the head gasket was replaced, iam thinking it could be air in coolant or vacuum leak or just a simple iacv or the the thermal valve i forget wat its called
