vtec-e?
Old Sep 18, 2007 | 02:38 PM
96DX4dr4life's Avatar
96DX4dr4life
Default vtec-e?
some dood posted this vtec-e thing iin his descriptino about his 97 HX on craigslsit. it sounded funny but it looked like it might be a real thing. ive never herd of it. im not planing on buying th car anyway but i was jw is this real?
SOHC VTEC-E
Honda's next version of VTEC, VTEC-E, was used in a slightly different way; instead of optimising performance at high RPM, it was used to increase efficiency at low RPM. At low RPM, one of the two intake valves is only allowed to open a very small amount, increasing the fuel/air atomization in the cylinder and thus allowing a leaner mixture to be used. As the engine's speed increases, both valves are needed to supply sufficient mixture. A sliding pin, which is pressured by oil, as in the regular VTEC, is used to connect both valves together and allows the full opening of the second valve.
Old Sep 18, 2007 | 03:35 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
VTEC-e was used in the 96+ HX and 92-95 VX hatch.
VX - D15Z1
HX - D16Y5
Old Sep 18, 2007 | 03:39 PM
Wharbone's Avatar
Wharbone
It is the real deal. Just a VTEC engine that is good with fuel ecconomy.
