FS: 2001 ITR Acura integra Type R Turbocharged ITR TURBO CHEAP!!!! MARYLAND
turbo specs
manifold: cast inline pro SS 375
downpipe: 3" spooling SS downpipe/Hytech collector 3" tapers into 2,5" 425
dumptube: stainless steel 95
wastegate: turbosmart 38mm ultra gate flat black 225
custom a/c line to clear this setup 105
includes 12.9 grade bolts
$1225
turbonetics t3/t04b great condition, no play 50 trim t04b t3 .48 a/r stage 2 wheel. cold side is polished.
$295
inline pro aluminum 2.5" IC piping + Treadstone intercooler with brackets will bolt right up to integra. comes with 2 hks style bovs, one before TB, the other right before IC includes t bolt clamps and couplers
$595
aluminum intake with k&n cone filter, complete with couplers/clamps
$55
s200 boost dataloging p72 chipped and ready to go.
$495
oil retun line/send line, aeromotive alum fittings, 90 and 45, 300 degree hose, flame resistant sleeve. will include extra 1' of hose
$95
3 bar map sensor with pigtail, no slicing, its plugs right into integra harness!!!!
$95
vented itr valve cover with aeroquip swiwel 90 degree fittings with 300f hoses to dump on the side, additonal check valves and fittings for pcv valve to IM with bypass. <-- this will save or extend the life of engine, a must have
$195
2.5" exhaust and smsp carsound cat, stainless steel madrel bent
$295
siemens deka saturated 630cc injectors have true flow of 630cc and can flow 700 some cc (i gotta find the link to specs) under 50 or 60psi..
$210
Blitz Dual SBC boost controller - New solenoid - works excellent, 5 boost settings control hp within the car - $245 additional fittings/lines
$1225
$295
$595
$55
$495
$95
$95
$195
$295
$210
i really like your car alot and i would love to buy it but i only have 7k cash and i would like everything to stay in it including the turbo i know you want like 9200 but if you work with me i could be to you on saturday with 7k cash. thanks
why does something like that matter anyway, its clean title.. the car has been sold, and you will not find anything remotely close for this price, it will be at least 3-4k more.. i regret selling it this cheap.. but live goes on..
