'95 Talon TSI AWD with 6-bolt in PA
I bought this car at the beginning of the year with the intention of building it into a fully built racecar but I have since moved out of state and don't have the time to build it or drive it so I am going to sell it. All internals on the engine were done on 7/1/03 with 107K on the car as was the clutch.
Ross pistons/Eagle Rods
Block balanced and blueprinted
Timing Belt replaced
4pc metal head gasket
ARP head studs
Ported head
Ported Manifold
Balance shaft elimination Kit
Water Pump replaced
Also has the following:
Hallman classic manual boost controller
Greddy turbo timer
K&N filter
ACT 2100 clutch
Toyo tires
DSM link
High Flow cat
Pioneer 6400cd monitor
Autometer lunar series boost/oil pressure gauges
2 gauge a piller pod
The car now has 121K miles on the chassis. It will need a tuneup or to have the lifters replaced because the do tap a little (very common in DSM's). The rubber bumpstops in the suspensions also need to be replaced. The battery was just replaced. The car is located in Easton PA. $5000 firm
ARP head studs
Ported head
Ported Manifold
Water Pump replaced
Greddy turbo timer
K&N filter
ACT 2100 clutch
Toyo tires
DSM link
High Flow cat
