fs/ft 1997 Fully Built Integra GSR Turbo *louisiana* CHEAP
Old Aug 7, 2007 | 10:41 PM
nuessly's Avatar
nuessly
Default fs/ft 1997 Fully Built Integra GSR Turbo *louisiana* CHEAP
TRADES WELCOME
http://good-times.webshots.com/album/559858629DbALsg
Turbo kit:this kit comes with 2 turbos. both are t3/t4 garrets. one is a 50 trim that the seals are blown out on(which is a 5-bolt),and the other one is a brand new 50 trim(v-band) never installed. Tial wastegate,Greddy trust BOV,Intercooler Piping,full race Intercooler,3bar map sensor,was tuned with neptune.autometer boost gauge,a/f in a frog eye pod.greddy digital boost controller. It also includs 3 inch downpipe,and a drag manifold which retains ac/ps. rc 850cc fuel injectors,and stock b-series injectors.
I replaced he turbo with a True Toda header (MSRP $998.99)
here are the updated pics of my car. i am looking to get into a new car.
I have a 97 integra ls with built gsr turbo. the color is type r yellow.
the motor in this car came from Jgenginedynamics.com
Im looking to get 9,000 with the turbo kit and 8,000 without it. these are O.B.O. im located in slidell, la 70461. throw out any resonable offers or trades.
EXTERIOR:
The exterior is agian type r yellow with shaved emblems, hatch keyhole,antenna, and molded front lower lip.
SUSPENSION:
This car has 16" rota grids (black with a polish lip)with tires that have 75% thread on the tires. the rims are in good condition.it has coilovers with front and rear skunk 2 camber kits.
INTERIOR:
The interior is factory but comes with type r gauge cluster,and type r interior excluding the seats.( i wish i had the seats).
*Hot tank and clean
*Step deck .003
*Resleeve Highest quality ductile iron
*Bore cylinders
*Power hone finished with sunnen AN300 stones
*Deck block surface with step deck
*Micropolish crank
*Balanc ultra balanced
*Main bearings using hand lapped oe bearings
*Rod bearings using hand lapped oe bearings
*Thrust bearings
*Oil pump type R
*Water pump type R
*Seals and gaskets new
*Oil pan Moroso
*Con rods Scat
*Pistons CP
*Piston size 81.5mm
*Comp ratio 9.0
*Ring pack CP
*Head studs ARP
*Head gasket OEM
*Timing belt New belt
*Camshafts Stock
*Cam gears jotech (extremely rare)
*Port work JG pro series
*Intake valve guides Tapered
*Exhaust valve guides Tapered down
*Valve spring retainers Titanium 6AL4V
*Valve springs JG dual
*Valve job Full radius intake and 3 angle exhaust
*Intake valves Stainless steel
*Exhaust valves Stainless steel
*Valve seals New
*Chambers Polished
*Cleaning Hot tanked
Old Aug 13, 2007 | 10:56 PM
the0ne's Avatar
the0ne
hey do you still have the car for sale im really interested
Old Aug 13, 2007 | 11:24 PM
nuessly's Avatar
nuessly
yes i do what are interested in doing?
Old Aug 14, 2007 | 09:41 AM
the0ne's Avatar
the0ne
Default teg
well see i live in California pa.. so I'd like have to get it shipped here i dunno how much that would be
Old Aug 14, 2007 | 03:09 PM
nuessly's Avatar
nuessly
Old Aug 16, 2007 | 10:41 AM
Hondasi88's Avatar
Hondasi88
hey mr theone can u return my calls and get my plates back to me!
u have all my contact info
Old Sep 9, 2007 | 11:24 AM
thekleenexman's Avatar
thekleenexman
whats goin on man matt morgan here im from slidell hit me up im lookin to buy a car, 9852859178 thanks.
