car seems to want to turn off when i stop
Old Oct 7, 2002 | 07:08 PM
wesleypipes1338's Avatar
wesleypipes1338
Default car seems to want to turn off when i stop
lately it would happen if i stop suddenly, but tonight i came to a slow stop and it got closer to turning off. my fuel pressure gauge shows a constant 30-32 psi. im not sure where to start looking.....its a 94 accord ex auto.
Old Oct 7, 2002 | 08:36 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
What's it idle at normally? Have you tried raising the idle speed?
Old Oct 8, 2002 | 04:45 AM
wesleypipes1338
it idles normally at 700-750 rpm, so its in spec. i havent messed with the idle speed in a while, so ill raise it a notch and see if it helps. also, hopefully it has nothing to do with my tranny slipping, but im taking care of that within the next two months.
Old Oct 8, 2002 | 02:41 PM
wadzii's Avatar
wadzii
fear the dark side
my old accord started doing that.. never figgerd it out, it went away when i did the swap
Old Oct 8, 2002 | 03:42 PM
wesleypipes1338
what did you try to fix it?
Old Oct 8, 2002 | 04:21 PM
wadzii's Avatar
wadzii
fear the dark side
jdm h22a/auto
Old Oct 8, 2002 | 04:25 PM
wesleypipes1338
jdm h22a/auto
lol
Old Oct 8, 2002 | 04:41 PM
2low2towHB's Avatar
2low2towHB
vacum leak. I had, or I should say have the same dilema
Old Oct 8, 2002 | 04:44 PM
wadzii's Avatar
wadzii
fear the dark side
i jus figgered it was the tranny cause it only did it when i had it in drive...... so i said to hell with this **** and swaped it
Old Oct 8, 2002 | 06:54 PM
wesleypipes1338
maybe, my hoses at the intake manifold are kinda easy to pull off, and it didnt seem to bad today. ill figure somethin out tomorrow after work. thanks for the help guys!
