rings and bearings...
Old Mar 3, 2007 | 05:02 PM
Redlinerz's Avatar
Redlinerz
Default rings and bearings...
what do you guys perfer using? I am doing a simple all motor build and thinking of going with OEM rings but not sure of what bearings.. my machinist stocks clevite bearings.. any good? I have also heard some bad things about ACL.... any input of this? What rings do you perfer and why? And what bearings do you perfer and why? thanks!!!
Old Mar 3, 2007 | 08:48 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Bearings: OEM (plastigauged to the correct spec). ACL are great bearings if the specs are correct.
Rings: OEM or whatever come with the pistons
Old Mar 4, 2007 | 12:02 AM
2001TEGGSR's Avatar
2001TEGGSR
Agree, OEM bearings only. OEM Rings with OEM pistons. If your using forged pistons then I would use whatever they supply.
If your crank is still a virgin, and your machinist is suggesting Clevite bearings then I would probably question his measurements. Just my 2 pennies.
Old Mar 4, 2007 | 03:10 PM
Snoopy's Avatar
Snoopy
been there done that
whatever gives you the desired clearances. oem, clevite, acl, king, etc.
Old Mar 5, 2007 | 07:31 AM
Jan Niemi's Avatar
Jan Niemi
Definitely go with OEM bearings.
I'd personally replace the pistons as well, but if you don't want to, then just get OEM rings as well.
The beauty of using OEM bearings on a Honda is that the factory bearing codes are stamped right on the block and crank. Just check your crank journals with a good micrometer to make sure it is still within spec. (it should be because it's nitrided, unless you had an oil starvation problem)
Old Mar 5, 2007 | 01:20 PM
Redlinerz's Avatar
Redlinerz
the bearing codes are on the back of the block and crank?????? i never knew that.. ima go outside and check that out.. would you happen to have more of a exact location/area i should be looking and what does the code look like? letters? numbers? sorry for all the questions
Old Mar 5, 2007 | 02:57 PM
Snoopy's Avatar
Snoopy
you have to remove the oilpan to see the codes
Old Mar 6, 2007 | 12:14 PM
Jan Niemi's Avatar
Jan Niemi
I never said they were on the back of the block.
Here's a photo of my block with main tunnel codes visible:
The journal codes are on the crank
File Type: jpg
