1992 Civic Si for trade (NY)
This is a 1992 honda civic si hatchback
has a single cam a d16y7 non vtec with a d16z6 TB and inatke manifold injectors and tranny but the computer is not a p28 its a p2e
oil change every 3,000 miles
has a new starter
new front windsheild
a 1 year old full straight pipe cat back exhaust
sunroof works
has a sony radio faceplate
has GSR seats expect the left rear seat (is stock) the seats have a little damge but still good...front right seat needs head rest
brakes are still good and has enough life..if you want to it still has enough to cut dem
everything else is pretty much stock
The bad:
needs a passenger side window regulator and key entrance
need a dimmer switch
timming belt off by one tooth (will fix myself)
needs a extra ground from the battery to the starter (will fix myself)
bad bushings...has a double wish bone suspension so bushings arent dat much
needs paint job everything is good to fix and take out bumps and dents but must replace hood besides that its all good
Looking for trades only, not sure what i'm looking for, no rush, Open to any offers,
Live in new york, would travel for good deal
has a new starter
sunroof works
The bad:
89 turbo supra with targa top... only has a stg 3 clutch. 164,000 miles 5 speed with.... AFTER MARKET GAUGES!!!!! lol... fun car. driver side door is offline (easy fix) and none of the options on the driver's door doesn't work because the douche that owned it before me cut the wires because he was gonna try and put a vertical door kit on it. lol. so he cut the f+++in wires like a dumbass. but it's a fun car. LSD EQUIPPED. needs body work though. the tranny still needs to be put in the car though. the clutch and everything is assembled... just need to be bolted up. hahaha i also like the pic with the cop. roflol
