FS/FT 1998 eclipse gsx fully built in NJ..
1998 eclipse gsx-2.3L stroker
4G63 6 Bolt Block(800awhp capable)
2.4L Crankshaft
85.5mm Bore (.020 over)
Eagle H-Beam Rods
Wiseco Forged Stroker Pistons
New Topline Front Cover w/ Oil Pump Gears
Balance Shaft Eliminator Kit
New TRW Water Pump
Motor Mount Driver Side
Cometic Head Gasket
ARP Head Studs
Timing Belt Kit Fully Installed and Timed
Mitsubishi Cam Gears
Comp 101200 Cams
4G63 Oil Pan
Oil Pickup Tube
Now for the head!
Stage IV Head
• 100% Hot Tanked
• Fully Pressure Checked
• Competition Valve Job
• Stage IV Port Work
• New Valve Stem Seals
• Stainless Steel Swirl Polished, and Undercut Valves
• New Valve Guides
• Manley Springs
• Manley Titanium Retainers
• Fully Decked Head Surface
• New OEM Exhaust Manifold Studs
EvoIII 16G turbo.walbro255hp.S-AFC2..good for 11's in the 1/4 mile
have more pics..mellon_ray@yahoo.com
looking for cash or a trade plus cash..if interested call RAY(609)351 8452
2.4L Crankshaft
Eagle H-Beam Rods
New TRW Water Pump
Cometic Head Gasket
ARP Head Studs
Comp 101200 Cams
4G63 Oil Pan
Oil Pickup Tube
Now for the head!
Stage IV Head
• 100% Hot Tanked
• New Valve Guides
• Manley Springs
