FS: Drag Civic
Old Jan 21, 2007 | 05:48 PM
tubceevxwm's Avatar
tubceevxwm
Default FS: Drag Civic
For personal reasons the race car has to be sold. No cutting corners on this project. Pretty much ready to go minus a powerplant and cluth...Here are specs on car.
92 CX body with 12pt mild steel roll cage done by Brent Rau and Devon Pierce (will pass 9sec inspection)
MB wide one piece front end
MB fiberglass doors and trunk
Lexan windows
MB custom solid beam rearend with the width shorten 1" each side.
Progress drag suspension
Wilwood drag race front brake system with dynalight calipers front and rears.
Drive Shaft Shop Level 5 axles and hubs
C&R radiator and FAL electric fan
Painless 8 panel fuse switch.
Jegs universal dash
Ken's Kustom wheelie bar
Wilwood direct pressure brake master cylinder and Staging brake..
Sparco Steering wheel
95 Ls tranny with drag spool...and proshift by liberty gear
Autometer Boost, Oil, Water, 5" ultrapro 11K shift tachometer
MSD 7AL-2 ignition box, 2 step and external coil
F.A.S.T speed pro with honda harness EMS unit.
Kirkey lightweight seat with custom OEM bracket (Seat can move back and forth for different driver).
S.F.I. 6pt belt harness and window Net
1 gal Jegs fuel cell
turbostart race battery and charger
Precision PT66 turbocharger
Precision liquid to air intercooler PT900 handle of 700+ hp 3" outlet
Tial 46mm wastegate with Tial 50mm blow off valve
Full-Race equal lenght stainless manifold T4 (turbo facing sideways) same one on Kenny trans Civic
AC Autotecnic Race B16 intake manifold with Holly 68mm TB
Hasport mounts
Bogart Pro 4 front and rears with Mickeys 26X10X15 front and 24X4.5X15 rear (brand new)
Tin work on doors and rearend... Type-r White
Might of miss little details...
A lot of time and money was spent in this project. Well over 15K just in chassis, parts and time...All that would need is a powerplant, clutch and injectors and it's on it's way to 9's easy in this setup..Looking to get 7500 obo (alot cheaper than most race car out there selling) It will cost somewhere in the vacinity of 15K to build this kind of race are. Will help anyone who is interested to completely make it run...here are some pics.
Old Jan 21, 2007 | 09:25 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Bump for a great looking civic.
Old May 27, 2007 | 06:45 PM
tubceevxwm's Avatar
tubceevxwm
still for sale...really need this gone...
