what ratio fmu do i need for a b18b1 94 integra
Old Jan 17, 2007 | 04:08 PM
alanrey82's Avatar
alanrey82
dj uncle al
Default what ratio fmu do i need for a b18b1 94 integra
im gonna put a turbo kit together but im not sure what ratio fmu to use for the system its only gonna be 7-8psi on a stock motor for now until i have money to get an engine built.also i would like to know if i can use a catback exhaust or if it needs to be turboback.
Old Jan 17, 2007 | 04:12 PM
Snoopy's Avatar
Snoopy
been there done that
do not use an fmu to start with. get bigger injectors and a bigger fuel pump along with a tuneable ems. then have it all tuned. dont cheap out on a turbo setup or you end up paying even more in the long run.
and you would still buy a catback and most likely modify it to fit the downpipe and cat/testpipe you use.
Old Jan 17, 2007 | 07:52 PM
dubcac's Avatar
dubcac
I
:werd:
FMU is a good way to blow a motor.
