cluster problems 98ls
Old Jan 8, 2007 | 09:41 PM
slammed98teg's Avatar
slammed98teg
Default cluster problems 98ls
heres the deal. when i bought my 98 LS the cluster was all messed up. my CEL is on, as well as the ABS and SRS, the gas gauge dosent work either but the gas light does work.....weird?!? i also went to run a test on the car and everything i fine. as for every thing else...tach, speedometer, temp and battery gauges work fine. i dont know if its the cluster itself or and ECU problem or what? i took it out and all the wiring and connections look fine......what do i do? HELP?!?!?
