Swap Complete Car Won't Start Help!!
Old Jan 7, 2007 | 07:49 PM
xtune50's Avatar
xtune50
Default Swap Complete Car Won't Start Help!!
Just swapped a B18A1 into a 98 Civic HX. There is no signal going to the injector. When I use my test light on the injector plug on one wire I get a current when the key is in the ACC position. The other wire which is the common YEL/BLK wire when I touch the test light to it the Fuel Injection fuse blows. When I use the noid light on the injector clips there is no signal going through. Any ideas??
Old Jan 24, 2007 | 06:39 AM
Phantomhatch's Avatar
Phantomhatch
what harness did you use for the swap?
