Integra 92 ls part swap
I drive a 92 Integra LS and i have heard that you can swap parts from the GSR to the LS with no problems...is this true? I thought that the GSR was a 1.7, and since the ls is a 1.8 will the parts fit? I have heard stories of people swapping cams, heads, etc etc...i have also heard that doing these part swaps gives you some considerable horsepower gains...i am pretty much looking to see if anyone has ever done this, if it is possible.
only way you can swap a cam is if you bring the head with it... The LS is a non vtec engine.... GSR is a vtec, having 3 cam lobes... it will not fit into the LS head... Everything but the engine should swap over fine though
:doh: vtec
only the 92-93 gsr had a b17a. everything from 94+ had a b18c1.
things that can be swapped from a b17 to your b18a:
- head and everything that goes along with it (with proper preperation)
- pistons
- tranny
- header
things that cannot:
- crank and rods (unless you want to majorly destroke your engine)
- pistons
- tranny
- header
things that cannot:
:doh: vtec
- pistons
- tranny
- header
things that cannot:
- pistons
- tranny
- header
things that cannot:
Give me a break I had spelt it right the first time... and the C and X are right next to each other...
so has anyone here done this before? Swapped a GSR head to a regular B18 motor?...if so, did you run into any complications or was it fairly easy?...i also have anpther question...and yeah, i feel like a dumbass asking this, but is there anyways to get "Free"(as in costing no money) horsepower?
free hp? remove ac and ps belts. that will "free" up power being taken to drive those components. doing some weight reduction also helps.
search for lsvtec. you'll find more than enough info.
