gsr lock and temp problems.
ok, so ive had two integras so far and they both have had the same problems. the door locks. when i hit the button they move half way and stop. it kinda defeats the purpose of having power door locks if you still have to crawl across the passenger seat to lock the door. anyone else have this problem. also ive noticed latley that my car never really reaches operating temp. i mean if im sitting in traffic it does, but on the highway the temp is barley above the first line, and i mean barley. any suggestions on this? thanks
Look into the helms manual and do the proper steps on trouble shooting the thermostat before replacing it. Its usually testing with micrometer and couple other things.
Hey did you ever fix your ect sensor?
Originally Posted by red94teg
as far as your temp issue, it sounds like your thermostat is stuck open. try replacing that and see if it makes a difference.
No need to test it...the thermostat only costs $12 from Acura. It is two bolts to replace.
The dealership didn't do a whole lot in the way of fixing them. They took a look at it a few times and claimed to have replaced a few parts, but nothing really stopped it from happening.
Thinking of it...Last spring I had to get the OBD replaced - it completely died and was setting my alarm off at random times. Since the keyless entry and alarm are tied into the same system, maybe it was the same problem that was messing with the door locks...
