'95 GSR Sputtering
Old Dec 2, 2006 | 05:56 AM
trickthepony's Avatar
trickthepony
Default '95 GSR Sputtering
Hi -- I have a 95 Integra GSR. This summer I have driven that thing like crazy -- since July put about 10,000 miles on it because I moved and have had a long commute to work after checking out various cities in Texas. It has been very reliable so far, but inevitably something needs to be fixed. Anyway, I have changed the oil every 3000 miles and whatnot. I'm coming up on 120,000 miles. I am going to have the timing belt changed (and it was changed at 60,000 previously). Also will have oil seals replaced and get a new power steering hose. My current issue is that in the past 2 days or so my car has been sputtering in low RPMs. When idling it is ok, but when I take off from a stop, sometimes it sputters, and then all of a sudden it seems to engage normally and get up and go. Also if I am driving around and pull into say, a parking lot, engage the clutch, and then disengage the clutch in 2nd or 3rd gear, sometimes the sputtering will happen, kind of a "chug-chug-chug" and then it goes ok. It doesn't happen every single time, and it is not dependent on what gear I am in -- only on RPMs. Any idea what is causing this?
Old Dec 2, 2006 | 11:45 PM
tommyhcky13's Avatar
tommyhcky13
my friends car was doing the same thing. change your plugs and wires and distributor car and rotor. make dure you only put one seal on the distributor cap though
Old Dec 5, 2006 | 02:07 PM
boostequipped's Avatar
boostequipped
do a basic tune-up and see how it goes from there.
Old Dec 5, 2006 | 05:23 PM
AdNaMa585's Avatar
AdNaMa585
Amanda Backwards
Definitely try changing your plugs and wires. Mine did that for a while, and I was lucky because that's all it took to fix it.
Old Dec 5, 2006 | 05:48 PM
DaGip's Avatar
DaGip
4N2Ner
I'm having the same problem. when i stop for like 5min it goes away, but comes back if i push it, does yours do the same. only thing i have not touched was the IACV and the cap/rotor. try replacing those first before you try to get a new IACV cause it wont be cheap.
