What Timing Belt
Old Dec 1, 2006 | 12:31 PM
Zedron's Avatar
Zedron
Turbo B20
Default What Timing Belt
I just put a B20B in my 94 Teg and am using teh B18B LS head on it. What timing belt do I need to use? The one for teh b18B is too small and teh CR-V one is the same part number as the B18B one so it too is small. Thanks
Old Dec 1, 2006 | 12:56 PM
2001TEGGSR's Avatar
2001TEGGSR
Are you sure it's too small and the tensioner isn't getting in your way?
Start from the crankshaft, then go around the water pump and tensioner (without the spring load), then to the intake cam and exhaust cam.
The head's should be the same casting, I don't see why the timing belt is too small. Good luck!
Old Dec 1, 2006 | 02:17 PM
Zedron's Avatar
Zedron
Turbo B20
LS Belt tooo small.
GSR Belt tooo big.
??? Belt just right
I have a ITR Water Pump, would that make a difference?
Old Dec 1, 2006 | 02:39 PM
Snoopy's Avatar
Snoopy
been there done that
yes. if you use a vtec water pump you need a vtec belt. any gsr/itr belt will work. b16 belts will not work.
Old Dec 1, 2006 | 02:41 PM
2001TEGGSR's Avatar
2001TEGGSR
The ITR Water Pump should be the same as GSR. Are you sure the GSR belt is to big?
I'm stumped on this one. GSR or LS/B20 timing belt should work...
edit: Okay as snoopy said, use the GSR belt.
Old Dec 5, 2006 | 07:55 PM
Zedron's Avatar
Zedron
Turbo B20
I got it but it seems REALLY tight, hope it doesnt snap.
Thanks
