Quick question about 4x100 lug wheel offset.
Old Nov 29, 2006 | 12:03 PM
19Accord94's Avatar
19Accord94
Default Quick question about 4x100 lug wheel offset.
Just wondering if the old school 4 x100 lug BBS wheels found on some volkswagons and BMW's would fit up to the acura 4x100 lug pattern. Maybe be a dumb question but wondering how much off the offset would be. or if its not a fit at all.
Old Nov 29, 2006 | 01:36 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
It depends on what the offset of those rims is. :shrug:
Old Nov 29, 2006 | 01:41 PM
Driverman5777's Avatar
Driverman5777
What size are the rims?
Old Nov 29, 2006 | 04:35 PM
19Accord94's Avatar
19Accord94
im just wondering if the factor 15" volkswagon 4lug is the same as the factory honda 4 lug 4x100. I found some 4 lug old school BBS wheels off an 4 lug volkswagon and im wondering if all the 4 lug volkswagons are the same as the civic/integra lug. they are both 4x100 just wondering if theres some weird thing that makes them not fit right .
Old Nov 29, 2006 | 05:40 PM
Driverman5777
it depends on the offset I believe you are looking at between 40 and 42
Old Nov 30, 2006 | 08:35 AM
fastback's Avatar
fastback
Maybe you are confusing the terms. 4x100 refers to the BOLT PATERN, and has nothing to do with the offset. Yes that bolt pattern will work. There is also an offset to the rim, which determines where the rim sits in relation to the car - that is also important for a number of reasons, so you need to find out what offset the other rim is and whether that will work.
