what rod bolts do i have???
Old Nov 28, 2006 | 04:46 PM
ginomobile/teg's Avatar
ginomobile/teg
Default what rod bolts do i have???
Hey, i bought a b20vtec for my DB1. It was a pretty good deal at 750$cdn.
But my problem is that i dont know how to tell if it has stock connecting rod bolts or ARP. How can i tell the difference??? Also how can i tell if head studs are stock or not?? I dont want this thing to grenade on me.
any help would be awesome!
Old Nov 28, 2006 | 06:50 PM
ginomobile/teg
okay so i saw that my headstuds are ARP for sure, it is stamped on the top of them, my bad for not looking close enough. But still not sure about the connecting rod bolts, all i know is that they are about 5/16" in diameter if that helps any. Anybody know the diameter of stock rod bolts compared to these ones????
Old Nov 28, 2006 | 06:51 PM
2001TEGGSR's Avatar
2001TEGGSR
ARP Head studs will be studs in the block with a nut & washer which mates at the top.
OEM will be Bolts that you insert after the head is placed.
For the rod's, ARP will be bolts, factory will be studs with a nut.
Old Nov 28, 2006 | 06:55 PM
2001TEGGSR's Avatar
2001TEGGSR
See the rod bolts on Cyl. 2 and 3? They are ARP - which I marked/colored with a sharpie marker to determine which is I/E side of the motor.
Old Nov 28, 2006 | 07:42 PM
Snoopy's Avatar
Snoopy
been there done that
you have stock rod bolts. arp's i believe are 3/8''
Old Nov 28, 2006 | 07:46 PM
2001TEGGSR's Avatar
2001TEGGSR
ARP 2000 bolts can be: 3/8", 5/16", or 7/16"
Stock are studs & nuts...
Old Nov 28, 2006 | 08:12 PM
Snoopy's Avatar
Snoopy
well shit on my parade h:
Old Nov 28, 2006 | 08:42 PM
ginomobile/teg
so how hard is it to install ARP rod bolts myself?? Do i have to do any drilling and tapping for the new bolts? I have lots of mechanical experiernce if that is a concern (3rd yr auto. apprentice). Do the stock rod studs need to be pressed out with a press?
Thanks for the the help by the way guys
Old Nov 28, 2006 | 08:50 PM
Snoopy's Avatar
Snoopy
you need to have the rods resized to correctly install arp bolts
Old Nov 28, 2006 | 08:58 PM
ginomobile/teg
and can i do this myself? Will the machine shop just drill the holes out to 3/8" or whatever size the ARP's are? i just wanna see if i can save myself the trip to the machine shop if its easy enough to do myself.
