Need Help with Clutch Adjustment!!!!
Old Nov 28, 2006 | 12:46 PM
sugbear12's Avatar
sugbear12
Default Need Help with Clutch Adjustment!!!!
I just installed a new clutch in a 92 Acura Integra RS. New pressure plate, clutch plate, throw out bearing. Question: When adjusting the cable (not hydraulic) is the throw out bearing pressed against the pressure plate at all times? I figured with the pressure plate continually spinning, the bearing would wear out quickly. Any info for me!?!?!?!?!
Old Nov 28, 2006 | 02:10 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
There's a cable adjustment on the transmission where the cable attaches to the tranny. From my recollection, it's backwards in adjustment. Left will tighten it, right will loosen it. Test it out though.
Old Nov 29, 2006 | 01:41 PM
sugbear12's Avatar
sugbear12
I've tried it and it worked. However, my concern is the throwout bearing. Does it rest against the pressure plate at all times? Thanx again!
