which sub?
Old Nov 13, 2006 | 06:53 PM
88'CRX's Avatar
88'CRX
Default which sub?
Kicker Comp 05C104 or the Rockford fosgate p110s4?
Old Nov 13, 2006 | 07:24 PM
FrozenAcid's Avatar
FrozenAcid
you gotta explain a little bit more. what are you shooting for? what is the amp? Personally i like kickers more than rockfords, and the kicker has a slightly better sensitivity. But the rockford freq. range is lower. so what do you want out of the sub?
Old Nov 13, 2006 | 09:36 PM
b00gers's Avatar
b00gers
:werd: ^^
What amp is going to power it? What kinda box is it going into?
Old Nov 14, 2006 | 11:34 AM
88'CRX's Avatar
88'CRX
i was thinking of getting the kenwood kac-7202 to use for the amp?
Old Nov 14, 2006 | 12:00 PM
FrozenAcid's Avatar
FrozenAcid
the next big questions are what are you running for speakers? what about deck? are you going for more loudness, or do you want quality to be the main direction?
Old Nov 14, 2006 | 01:21 PM
Misa's Avatar
Misa
Pic Whore
the amp does 150 watts RMS x 2 at 4 ohms
both subs are 50-150 watts RMS
so a pair of either/or :dunno:
Old Nov 14, 2006 | 05:01 PM
97teg's Avatar
97teg
You cant use a pair cause they are both single 4 ohms and the amp is only 4 ohm stable bridged. Well not that you cant but youll be getting like 230 watts at 8 ohms bridged.
Old Nov 14, 2006 | 05:26 PM
Misa's Avatar
Misa
Pic Whore
its a 2 channel amp.... supports 150W @ 4 amps each.
Old Nov 14, 2006 | 05:27 PM
88'CRX's Avatar
88'CRX
im using a kenwood mp5032 head unit and i got sony xplod 4way speakers.. and wouldnt it send 4ohms to each channel?
Old Nov 14, 2006 | 05:45 PM
97teg's Avatar
97teg
True i forgot about a stereo configuration. Id only do that if the subs were in their own chambers however. Just to make sure that one sub isnt getting slightly different signal and causing distortion in the other. Most likely it wouldnt be a problem though.
Is there any reason your limiting yourself to those two subs?
