Need help with what i need for a B18A1 swap with my D15
Old Oct 9, 2006 | 04:51 AM
matt13's Avatar
matt13
Default Need help with what i need for a B18A1 swap with my D15
i just need to know what all i needto change in order for a complete swap i have a B18A1 with a GSR tranny so if u could help please.
Old Oct 10, 2006 | 09:26 AM
primetime's Avatar
primetime
You're going to need the LS motor mounts/ Gsr Tranny Mount the LS ecu. the motor should drop right in!
Old Oct 10, 2006 | 10:01 AM
matt13's Avatar
matt13
do u think i will need LS axles and i have a gsr wiring harness which im not sure if i can use it because its vtech but i heard u could as long as u dont hook the vtech up.
Old Oct 11, 2006 | 05:37 AM
primetime's Avatar
primetime
Yes you need the LS axles and you should really use the LS wiring harness!!!
Old Oct 11, 2006 | 09:04 AM
matt13's Avatar
matt13
The d15 was a hydraulic clutch and the GSR tanny is cable clutch is thier any way i can canvert either one to one or the other.
Old Oct 29, 2006 | 06:14 AM
gravesdu_99's Avatar
gravesdu_99
HASport makes a kit to convert your cable to hydraulic. Thats what i used in my car.
