5k rpm rev cut? HONDATA h22 turbo
Old Oct 7, 2006 | 04:17 PM
streeTTrendzH22's Avatar
streeTTrendzH22
Default 5k rpm rev cut? HONDATA h22 turbo
I'm getting a rev cut/limiter at about 5200 rpm. There is no cut in neutral. I'm using a hondata s300. I'm sure I'm getting sufficent fuel. We tried disabling pretty much everything. We checked ALL the setting- Rev limit was set to 8k, boost setting was plenty high. launch setting was disabled, we tried disabling v-tec, we disabled fuel and ignition cut offs, I'm probably forgetting some of the setting, but we went through all of them and tried everything. I have a 3-bar map,550cc inc.,walboro 255 fuel pump. It was consistent 5200 every time and didnt matter what gear. So any ideas would be greatly appriciated. thanks Oh I think I have a bad timing belt tensioner, its squelling. I'm not sure if that could be part of the problem?
Old Oct 7, 2006 | 07:30 PM
2001TEGGSR's Avatar
2001TEGGSR
Are you running OEM ignition system? Are you POSITIVE there is no launch control or setup? Be sure you re-enabled vtec.
Old Oct 8, 2006 | 07:26 AM
streeTTrendzH22
I'm running msd wires other than that its stock ignition, but I already had it tuned at 14psi and it was fine, but i cant even get back to that point. Yea we tried v-tec on and off. Since it was running good at 14 psi I had replaced the head gasket put a walboro 255 fuel pump in and now I'm having this problem. We had our A/F pretty good on the dyno so I dont think it was because it was to rich or anything? We completly disabled all the launch settings that we could find
Old Oct 8, 2006 | 08:04 AM
t3t4delsol's Avatar
t3t4delsol
do you have fuel maps made past 5200?
Old Oct 8, 2006 | 08:48 AM
2001TEGGSR's Avatar
2001TEGGSR
How about fuel pressure? Did this start immediatly following your pump installation? Might use a fuel pressure gauge to check, I think its supposed to rise as vtec engauges. I'm not too sure what else to suggest. Good luck!
