Wide tires - 95 Accord LX
Old Oct 7, 2006 | 01:46 AM
T07N's Avatar
T07N
Default Wide tires - 95 Accord LX
I'm pretty new to the wheels games. I'm wondering what's the widest tires that can fit well on my 95 Accord LX? I'm thinking of getting 17" rims later on, wondering how wide I can go?
Old Oct 7, 2006 | 03:01 AM
MTEng's Avatar
MTEng
"fit well" ? As in fit inside the fenders??
When you (properly) plus-size tires you're going to attempt to keep the tire circumference the same as stock.
Your car stock came with, what, 185/70-14 tires?
According to Tirerack you could do the following sizes:
195/60-15
205/50-16
205/45-17 <== :goodjob:
215/40-18
As you can see, they don't suggest anything wider than a 205... that's probably for fender clearance. As your tires/wheels get wider you start to need to add offset to move them more outboard so they clear the struts and other suspension components. The more offset you add the more you increase your chance of rubbing the fender lip.. especially in hard cornering and over big bumps.
Ride height matters, too, as is brings things closer together. What do you plan, if anything, for suspension mods and lowering??
Old Oct 8, 2006 | 01:25 PM
T07N's Avatar
T07N
Dang. 205 is not that wide... I'm planning to lower the car on KYB AGX shocks and H&R Sports springs.
Old Oct 10, 2006 | 03:01 AM
Black01's Avatar
Black01
There is a wheels games now? Is this under playstation, X-Box or Dreamcast?
