removed valve cover an painter it now car idles like shit an wownt run?
Old Sep 30, 2006 | 12:18 PM
juelz200486's Avatar
juelz200486
Default removed valve cover an painter it now car idles like shit an wownt run?
Hey all my fellow import peeps i removed my h22a valve cover an painted it when i put it back on the car runs like shit now it all shaking an running like shit wat should i do?help a.s.a.p
Old Sep 30, 2006 | 12:59 PM
teg92's Avatar
teg92
WHAT OK YEAH!
maybe you disconnected and vacuum hose by accident double check everything around the valve cover
Old Sep 30, 2006 | 01:17 PM
t3t4delsol's Avatar
t3t4delsol
tps?
Old Sep 30, 2006 | 07:35 PM
SirHybrid's Avatar
SirHybrid
Pcv hose? Did you reinstall all the gaskets and grommets? There are the 8 that go under the acorn nuts that hold the VC on. one around the pcv hose. Four in the inside around the spark plugs. The main VC gasket. The breather hose from the intake to the VC. 2 ground wires also!!!! If you don't have a ground hooked up, this could be your problem. I just put my red Type S valve cover on last night, so all of this is real fresh in my memory. Also, post up some pics. I'll get mine up soon too.
Old Sep 30, 2006 | 07:46 PM
Buyimports2's Avatar
Buyimports2
Are your spark plug wires on all the way? One of mine wasn't all the way down and I could definetely feel it.
