f20a sohc
Old Sep 18, 2006 | 03:13 PM
ludespeed88's Avatar
ludespeed88
Default f20a sohc
i have a sohc non-vtec f20a but have heard that they come in dohc so is there any way i can change the sohc to dohc without changing the head. i also heard they come with 150 hp which is from the accord si jdm. so why is it non-vtec and sohc?
Old Sep 19, 2006 | 10:04 AM
4cylinder4ever's Avatar
4cylinder4ever
look most readers would just past this question by, but I'll try to help you out a bit.
the only way to not change the head from a SOHC to a DOHC is to do a complete swapp.
but the easiest way is to change the head only from the SOHC to a DOHC.
the only problem I have is that I dont know if doing the head swap would work.
hope this helps.
Old Sep 19, 2006 | 02:27 PM
VietGuhTrippie's Avatar
VietGuhTrippie
Chijo Ecchi
Old Sep 19, 2006 | 02:29 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Stay far far away from your car....
Old Sep 21, 2006 | 11:57 AM
ludespeed88
what i meant to say is that can you change the head and make it a dohc.
Old Sep 21, 2006 | 12:08 PM
flyromeo3's Avatar
flyromeo3
No......
#1. the coolant lines will not match up. ( meaning antifreeze will not flow properly )
Old Sep 21, 2006 | 03:25 PM
totalimmortal
MalleusMaleficarum
No you didn't.
Old Sep 21, 2006 | 11:22 PM
Kai's Avatar
Kai
Rotorphile.
I've never heard of an F20A single cam. Do you have an 86-89 Accord? That's an A20A, 2.0 single cam.
Old Oct 2, 2007 | 01:51 PM
WEENUSS's Avatar
WEENUSS
Default yes there are f20a single overhead
i have a 91 4 door that i did a swap from a f22 to the f20a
Old Oct 2, 2007 | 09:17 PM
wedley2's Avatar
wedley2
bboy Wesley West
they are jdm, we have one in the project car im building.
same as a f22 just shorter stroke so it revs quicker. it is suppose to redline at 8k however it probably doesnt even make power at those rpms aka (ruins people's motors)
