b20 swap little problem
It's been long since i posted up here, got out of cars in to bikes but recentlly hydrolock my b18b and just installed a b20b. Now the car runs nice, feels like more power but when i push the car hard up to red line check engine comes up. obd2 pc tells us the car is running too lean-ritch. So now i gues i would need a FPR to increase the amount of fuel to the motor? Anybody else had a problem like that. That little increase in displacment( 0.2) would make that big of a difference??
thanx
guys
thanx
guys
thanx
guys
thanx
guys
well i hooked up another obd2 scanner and it showed me code i think it was p0171 which means pretty much the car is running lean. I'm running a b18b computer maybe i will need a crv computer?? this thing is killing me lol
The B18B1's ECU fuel map is suited for a smaller displacement motor (obivously) and it stands to reason that the injector cycle is a little too short for the B20B.
Moved to Engine Swaps..
thanx for your help guys. another question
can i just get apex afc and use it to change the fuel map or maybe get my b18b computer and reprogram it with a custom map???
that is BS the b18b actually has a higher compression ratio and requires a larger amount of fuel. if anything the b20 needs less fuel. i have seen many dyno maps and the b20 using the b18b ecu usually needs fuel taken out. there are other issues here
