What amp to power SWR-1522D??
15" Alpine Type-R SWR-1522D
This sub is 1500 watts peak power and 750 rms (dual 2 ohm). i was wondering what amp/amps i could use to power this???
so far the best ive found was a mono amp ALPINE MRP-M650. it has 600 watts continuous rms at 2 ohms. i really dont want to spend more than $250 on an amp.
anyone got any other suggestions??
Do you already have the sub?
For that particular sub you want an amp that gives off the most power at 1 OHM or 4 OHM, NOT 2 OHM. There is no way for that sub to become a 2 OHM sub. You can only wire it in series, which will turn it into a 4 OHM sub, or in parallel, which will turn it into a 1 OHM sub.
There are a few high powered amps that can go down to 1 OHM.
http://edesignaudio.com/category.php?type=amps
The first amp is a little too much power and a little too much in cost, but its one hell of an amp.
ok so let's say i had an amp that produces
100 watts RMS x 2 at 4 ohms
125 watts RMS x 2 at 2 ohms
250 watts RMS x 1 at 4 ohms
how much power would that produce at 4 ohms for my sub? and could i use 2 of these amps to produce even more power??
sorry for the basic quetions. yes, i do have the sub.
That BXi1606D is a nice amp at a bargain price, but you'd have to be very conservative on the gains. It'll give you plenty of headroom in case you want to upgrade to a sub with higher power ratings in the future.
You may also want to check out the BXi606. It'll give you 600W RMS and is roughly $75.00 cheaper.
http://www.onlinecarstereo.com/CarAu...roductID=16363
that's awesome man. im strongly leaning towards that one now.
anyone else know any good amps that can put out some good numbers at 1 or 4 ohm?
