93 civic si won't start
Old Aug 2, 2006 | 01:29 PM
spooncivicb16b's Avatar
spooncivicb16b
Default 93 civic si won't start
as it says the car doesn't seem to get spark and the fuel pump doesn't start either.anybody have an idea what could be going on
Old Aug 2, 2006 | 02:18 PM
fastback's Avatar
fastback
Did you check the fuse? If you don't hear the fuel pump and the fuse is good, your pump may be dead. It could also be the main relay (PGMFI relay). Battery is OK and everything comes on when you turn the key but you don't hear the pump?
