Car Troubles
Old Jul 29, 2006 | 11:20 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Default Car Troubles
1989 CRX Si.
I was teaching my friend how to drive a little stick and after a while we took it onto a larger deserted road. He was in second, clutch in, shifted into 3rd, clutch out and it started bucking a little so he gave it more gas, but nothing happened. He pulled over and when he stopped the lights came on that come on when it stalls(Batt and oil?). I go to start it again but no luck. Its turning over(So its not the starter) but won't start. If you keep the key turned for a while it sputters a bit and it sounds like a sheet of metal getting shook back and forth kinda. I don't know if its the fuel pump. I think it has enough gas. Gas gauge says 3/8s full with 239 miles(About right I guess. Maybe a little high of miles)
What should I look for? Could it be flooded? We pushed it 8 blocks to his house then tried it again(15 minutes?) and same effect. I'm going back tomorrow morning to put in more gas and try it again.
Old Jul 29, 2006 | 11:22 PM
dE.fUsEd's Avatar
dE.fUsEd
I still like honda's. :-/
Fuel injection doesn't flood.
Make sure you have gas in it. Go fill a 5 gallon jug and put it in there.
Old Jul 29, 2006 | 11:25 PM
RB's Avatar
RB
snitches get stitches
something in the distributor maybe? thats what happened when my cap/rotor needed to be replaced.
Old Jul 29, 2006 | 11:30 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
I'm going to take a quart or two of oil over as well as some gas and check it out.
I'm hoping its something simple like that.
I didn't think FI flooded, but wasn't certain.
I don't know if the fuel pump was working, I'm not sure what it sounds like or anything.
Old Jul 29, 2006 | 11:32 PM
dE.fUsEd's Avatar
dE.fUsEd
when you turn the key to the ON position, you should hear a short humming noise coming from the rear of the car. that's the fuel pump engaging.
it may be hard to hear, but i think CRX's have it under the rear seat like newer civics do.
Old Jul 29, 2006 | 11:33 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Never heard that.
Old Jul 29, 2006 | 11:43 PM
fstop128's Avatar
fstop128
fuel injection does too flood. check your distributor.
Old Jul 29, 2006 | 11:45 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
What do I check in my distributer? I don't know what to look for.
Old Jul 29, 2006 | 11:46 PM
RB's Avatar
RB
make sure the screw that holds the rotor on is tight. Check for corrosion on the cap/rotor. Usually the cap/rotor stop working due to a weak electrical connection so its not something that will be blatantly obvious to the untrained eye.
Old Jul 29, 2006 | 11:52 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Okay.
I'm going to try to get my neighbor with a trailer to tow it back to my house if I can't figure it out there. AAA won't tow it this far away.
I do miss not having anything wrong with my teg.. I saw a teg that looked like mine yesterday and I got a little sad. IBItsA17YearOldCar
