The truth about synthetic oil. From Castrol USA
Old Jun 9, 2006 | 08:26 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Default The truth about synthetic oil. From Castrol USA
I wrote them a letter cause I wanted to know, if switching to syntec after conventional can cause leaks and here is the answer.
A quality synthetic motor oil can be used in old as well as new cars,
including cars in which conventional oil was previously used. While
using a synthetic motor oil in newer cars has been well documented, Castrol
SYNTEC also provides added protection through enhanced seal compatibility-
which is extremely important for used cars. Therefore, synthetic motor oils are
beneficial for the good health, long life, and top performance of new
and old cars. And any consumer looking to get the most out of their car
should consider using a premium Synthetic motor oil.
Castrol SYNTEC full synthetic motor oil will absolutely not cause a
leak in a high mileage engine. This is a common misconception.
However, although a synthetic will not cause a leak, it could
potentially find one in an engine that has a pre-existing leak. In fact we don't
recommend switching to a synthetic oil especially if you are already
experiencing a leak, because it will make a leak more apparent.
This is because Synthetic oils contain 'Detergents' that will
immediately begin to clean away any sludge or buildup in the engine, particularly
around the seals where sludge likes to gather. Detergents help your engine run
clean and cool and therefore efficient. If however, you have any
damaged seals currently blocked by this sludge, a synthetic oil will wash the
blockage away and make an existing leak more apparent. This should not
be a worry if you have a well maintained engine. The sooner you use a
synthetic the better. Many vehicle manufacturers use Castrol Syntec in there new
cars and trucks right off the line.
There is also the option of GTX High Mileage, a conventional oil with a
special additives package that benefit engines over the 75,000 mile
mark.
Old Jun 9, 2006 | 08:29 PM
RB's Avatar
RB
snitches get stitches
nice formating.
Old Jun 9, 2006 | 08:31 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
fuck if im gonna read that haaaaaaaaaaaaah
Old Jun 9, 2006 | 08:32 PM
worm696's Avatar
worm696
Originally Posted by RB
nice formating.
I think it works well with the context of the explanation.
Old Jun 9, 2006 | 09:36 PM
Hans Stoner's Avatar
Hans Stoner
pimpin' south jersey
i ruined an engine switching to sythentic.......crap I tell you, crap!!!
Old Jun 10, 2006 | 10:50 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
As far as the formatting goes I guess I can fix it. I just cut and paste the email and that is how it came out.
Old Jun 10, 2006 | 11:17 AM
dubcac's Avatar
dubcac
I
I'd rather run dino oil and change it more often.
Old Jun 10, 2006 | 11:20 AM
RB's Avatar
RB
I'd rather run synthetic and be a lazy asshole.
Old Jun 10, 2006 | 12:10 PM
Grifter's Avatar
Grifter
id rather run synthetic and be a
o wait
Old Jun 10, 2006 | 01:25 PM
TeggerLS's Avatar
TeggerLS
I change my synthetic at 15k miles now... no reason to change sooner h:
