1992 Honda Accord Starting Problems
Old May 30, 2006 | 06:29 PM
eulis's Avatar
eulis
Default 1992 Honda Accord Starting Problems
My 1992 Accord won't start at times. The engine turns over and fires well but will not start. At times there is no gas going to the injectors (I took fuel line loose and tried to start, fuel didn't squirt out at a fast rate either). I can spray starter fluid into the air intake plenum and it startsand keeps running. Fuel pressure has checked out fine. Electric fuel pump works. Today was the first time in three weeks problem occured again. This is an intermittent problem but when it happens I am stranded. Any ideas?
Old May 31, 2006 | 08:46 AM
flooredfab's Avatar
flooredfab
www.flooredfab.com
Accords have a common problem with the ignition switches going out. Have the electrical portion of the ignition switch checked out. The other most commom problem is the main efi relay located under the drivers side dash above the kick panel. Typically if the relay is bad they are bad and will not work intermitently. You may also have something as simple as a loose spark plug wire.
