325hp 2000 TURBO ACURA GS-R IN N. VA
Time to move on to another project. I am selling this well spoiled Integra for no good reason, I just cant use it. I have kept all maintenances up to date through my work (Fairfax Honda). Everything installed from the brake lines to the wiper inserts has been done with the up most care and professionalism. The turbo kit was installed on 8-18-2005 by Brian Fisher from Inline-Pro. The engine internals were installed by Matt Park at Fairfax Honda. The vehicle was obsessivly tuned to perfection and efficiency. The car currently dynoed at 324hp and 230 torque at only 13psi. I have Hondata and have the boost cut to 16psi. I did not install a turbo to race it only to satisfy myself with more power. I have currently driven the vehicle to get 24mpg city. I have not put this vehicle on any track and do not participate in any street racing. The engine is very strong and has had check ups for leak down and compression checks. The transmission is flawless unlike many other Integra's. I work alot so most of the time car just stays parked at work. I bought it three years ago with 36,000 miles for $16,000 and it now has 64,000 miles on it. The stereo was installed by New Sound by John and Frank Patton. It has been in two sound drags and has done very well for the class I get put in. It hit 141db in the 2000watt class or 15" sub class. All the wiring is a site to see and very expensive (no corners cut). Power and ground are 0 gauge Lightning Audio. The body of the vehicle has not been in any accidents and only has minor dings due to Fairfax drivers. I have had the dings pulled out at work by Professional Dent 3 times and people just seem to be magnetized to black cars. The things I did not get to do, new wheels and brake upgrade. Im accepting all offers and will work with any unreasonable offers. Items installed are as listed below. Thank You
Precision G60 turbo .60/.68
Precision 31.5"L x 8"H x 3.5"D.2.75" OD inlet/outlet.Will support up to 600hp.
Turbosmart 35mm UltraGate Wastegate
Turbosmart BOV Sniper series
Polished Stainless Steel 3" downpipe with 2.5" flex pipe (No Catalytic Converter)
Polished Dump Tube
Mandrel bent, 2.5" ID aluminum charge pipe kit
675cc Inline-Pro Injectors
Walbro 255lph fuel pump
CP Forged pistons 9:1 comp.
All new engine seals and bearings
Dual Slim Flex fans
Turbosmart boost controller
Hondata S200 with datalogger and boost option
3 Bar map sensor
Inline Pro polished stainless steal 3" Downpipe back exhaust
Act Organic Hybrid clutch
Suspension
Tokico Type-R adjustable coilovers (Illumina Type-R)
Rear Lower Tie bar
Goodwrench steel braided brake lines
17" Konig wheels with brand new Khumo 711 tires 205-40-17
All Honda brake pads
Audio
Sony M3Di headunit
Sony 6 Disc mp3 cd changer
Sirius Satelite radio
XM Satelite radio reciever (currently not subscribed)
Kicker KX800 component amp (1250watts rms)
Kicker KX600 sub amp (725watts rms)
Lightning Audio digital capacitor
All Lightning Audio wiring
Lightning Audio 220amp circuit breaker
New Optima yellow top battery
Kicker L7 10" sub
Kicker Resolution Highs 5 1/4's in the front and 6 1/2's in the rear
Kicker crossovers
Other
18% Formula One Tint all around
Greddy radiator cap
Stewart Warner boost gauge
Will come with extra's
12 Month old DC Sports 4-2-1 polished header
16 Month old AEM V2 intake
All stock components removed (not struts, wheels or exhaust)
Shipping will not be available for my car. The video link of the car being dynoed was in August at 281hp at 9psi. Thank you for looking at my car.
http://media.putfile.com/Acura...-Dyno
Polished Dump Tube
Dual Slim Flex fans
3 Bar map sensor
Suspension
Rear Lower Tie bar
Audio
Sony M3Di headunit
Kicker L7 10" sub
Kicker crossovers
Other
Greddy radiator cap
