RSX 2002 Side Door Locks Not Working
Hi. I have a 2002 RSX and I have a problem with my side door locks. My side door locks does not lock/unlock when I use my remote. Only the hatch locks/unlocks. The main switch by the inside of the door works fine since when I press it down it will lock/unlock ONLY the hatch door NOT the side doors again. When I manually press down the small knob by the window to lock the doors it can only trigger the hatch door not again the side doors. I don't if the lock motor is not working for both which is odd because when I press the knob by the side door it can send a signal so that the hatch door lock triggers. What could be wrong?
