FS:1994 Honda Civic Ex
1994 Honda Civic Ex Coupe
218k on stock SOHC d16z6 vtec motor w 5spd transmission
VIN avail. upon request for serious inquiries
Clean title
Power windows/power locks/power mirrors
Power Sunroof
Power steering
Cruise Control
The good & New parts replaced within the last year:
Front brakes, Aug.05
Rear Brakes, Jan. 06
Brake Lines in Jan. 06
Clutch, Jan. 06
Tires in Aug 05, 85% tread left
Poly Bushings in Front Control Arms in Aug. 05
Interior is clean, no rips or tears.
Body is in good shape for a Civic this age. There is NONE of the Typical Honda body rot, the car has not even begun to rot through. Car is not from NY, which explains the decent body on it. The only rust on the car is the surface rust that has just barely started. The body is solid and the quarter panels have never been retouched or reworked.
The Bad:
Check Engine light is on due to a faulty O2 sensor, minor problem and does not need immediate attention. Car does have a valid NYS inspection.
There is a dent and scrape on the passenger rear quarter with a small amount of surface rust just starting.
Front axle may need to be replaced.
Sunroof motor is weak.
Car is completely stock. I bought it from my cousin to use as a daily driver with plans to drop my b18 into it. I no longer wish to do that, i currently have 3 cars licensed, registered and insured on the road and i cannot afford to continue to do that, so this has to go.
Car runs solid, shifts smoothly and is a perfect candidate for a swap.
Contact me via Pm or email.
Vehicle is located in Lansing, NY 14882.
$2500.00 OBO
Clean title
Power Sunroof
Power steering
Cruise Control
Clutch, Jan. 06
The Bad:
$2500.00 OBO
Since the milage is so high, I can offer you $1900 cash. I'll have to pick up the car as well and gas is not cheap. Please take my offer into consideration... I had a clean 95 EX and totalled it two weeks ago in an accident with a tri-axle... don't ask lol
You can reach me at roc0487@hotmail.com
Thanks.
Thanks.
