Swap F22A1 with F20a DOHC
Old May 6, 2006 | 02:56 PM
atctower's Avatar
atctower
Default Swap F22A1 with F20a DOHC
Does anyone have the "how to" on this swap? I have a 1992 Accord Lx with some transmission and valve problems. I got the F20a DOHC motor. Just need some tips on install. Will my F22a1 ECU work? Any wiring problems that any one has experienced would be greatly appreciated.
Old May 22, 2006 | 09:46 AM
GreenEX's Avatar
GreenEX
I'm wondering the same thing. I also wonder what compatibilty there is between F20 DOHC and the H23A1 in terms of external parts. I'm building an H23A1 but using an F20A crank, rods and balance shafts, as well as .25 mm overbore H22 Type S pistons to make in effect a big bore F20A DOHC. Compression will be 11.6:1, the head has been ported, treated to a three angle valve job and stock cams will be using AEM cam gears. I'm going to have a crank scraper made for it, and I'm using a higher output H22 oil pump. There is plenty more to the build-up, and since I'll be swapping into my 1992 Accord, I'd like to know as much as possible about swapping and tuning it. Any info would be appreciated!
Old May 17, 2007 | 09:53 AM
JAPCONNECTION's Avatar
JAPCONNECTION
Default 93 Accord Ex
Hey I Am Doing A Swap On This Car It Was A Auto We Are Converting It To 5 Spd Using A F20a Motor And Tranny. We Are Hjavind A Problem With The Axles If You Know Please Help Me
Thanks
