speedo and mileage quit working
Old Apr 24, 2006 | 01:26 PM
laylow's Avatar
laylow
Default speedo and mileage quit working
i just bought my first honda,96' hb DX, the other day,ive been a huge volkswagen person so i dont know much about honda's, but i was driving to work and the speedo started jumping around like crazy from 0-80 and then 2 days ago i left my house and the speedo sat still along with my mileage and my trip, but before the trip and the mileage worked fine, so im sure its either the speed sensor or the gauge cluster, the reason im leaning more towards speed sensor is because the temp and the fuel gauge work fine, so heres the question is there any way i can test one or the other to see which one to buy, a new speed sensors is 91.20 and a new gauge cluster at the wrecking yards $50, thanks for any help
Brandon
Old Apr 24, 2006 | 01:29 PM
Civic2Scooby's Avatar
Civic2Scooby
you need a new VSS (vehilcle Speed Sensor)
Old Apr 24, 2006 | 01:32 PM
laylow's Avatar
laylow
thats what i was afraid of, are they a pain in the arse to put in?
Old Apr 24, 2006 | 01:33 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Agreed
No, one bolt and a wiring plug.
Old Apr 24, 2006 | 02:00 PM
laylow's Avatar
laylow
cool, thanks hopefully this means problem solved
Old Apr 27, 2006 | 07:01 PM
laylow's Avatar
laylow
ok i replaced the vss and still nothing, 92 bux down the drain but at least i know thats new, so i take it my only other option it the gauge cluster? or could there be another issue maybe wiring, how would i test it
Old Apr 27, 2006 | 07:09 PM
waaBAAH's Avatar
waaBAAH
sometimes the vss plug gets correded. pull the plug....take the white insert out with needle nose pliers.....then take a paper clip and lift up on the plastic tab holding the wires into the black vss plug. look for green oxidation...rust....or anything of the liking. either clean the metal tabs....or go to bone yard/junk yard and find a new or less rusty vss clip. small enough where it could fit in your pocket.....not saying you should take it or anything...lol i just payed 20 bucks for a stock 89 accord radio deck so i guess this is my way of paying those junkyards back. oh yeah...the display was cracked too...and i pulled it.
Old Apr 27, 2006 | 07:26 PM
laylow's Avatar
laylow
i just checked and the plug is spotless i couldnt find anything green or any build up on anything, we ran a diag. on it at work (i work for a GM dealer), and the diag. machine wasnt picking up anything as we drove around the parking lot,
Old Apr 27, 2006 | 07:42 PM
waaBAAH's Avatar
waaBAAH
not the plug part....but the wiring harness plug....the three metal wires from the wiring harness....
Old Apr 27, 2006 | 07:50 PM
laylow's Avatar
laylow
your talking about the part the plugs into the speed sensor right has three wire in it, because thats the one i checked, im so frustrated with this issue
