Reverse lights
I did a auto to manual swap on my civic about two years ago, and my reverse lights have never worked. I tried to wire them, so they do but all the instructions I have found are for 5th generation cars, and it doesn't seem to work for 6 generation cars. I already tried shorting the grn/blk wire to the yellow wire and that doesn't work. Does anyone know what wires I need to connect?
It's pretty simple. You know where the lockup up solenoid was in the auto plug that connector into the reverse switch. Then at the computer A17, A18 cut the wires the yellow and green/blk. Wire the yellow to where the shifter harness was to the yellow and same as the green/blk. That's it!
yep, just cut it because it's going to nothing since it's now a manual the ecu doesn't need to control the lockup solenoid. Just trust me I've done it and I'm a Master ase tech. Cut those wires and they will work without a doubt.
Here:
Or Here:
