srs light!!!
Old Apr 9, 2006 | 03:32 PM
hhh711's Avatar
hhh711
Default srs light!!!
Hey guys got a question. My srs light is on, tryed reseting it with the classic paper clip method, so i dont pay moeny to honda for nothin. And the light just wont go off, what should i do and what do you think the problem ????
Old Apr 9, 2006 | 04:22 PM
silvic00's Avatar
silvic00
did it just come on or have you done a mod, lately that could have caused this
Old Apr 9, 2006 | 06:30 PM
hhh711's Avatar
hhh711
Default wire
well here the problem it got stloen a while ago and when they broke the key lock thye tore the plastic cover covering the 2 wires that go the the steering wheel air bar and it came on...so i cut that and pulled out the wires and to give me elf mroe wires to work with put like a 3 inch portion of my own wire in between both (green, yello) wires to make a sure connection...that was 6 months ago, and has been fine ever since of course after doing that i reset it with the paper clip. and then yes about a week ago it just came on, mayby a short in the wires i used to connect the factory wires??? i redid the conections today with solder and heat shrink and reset it and after it blinks twice just comes right back on.
Old Apr 9, 2006 | 06:48 PM
JDMPONY00's Avatar
JDMPONY00
the only experience i had with an srs light is my mom had an accord wagon and the srs computer went bad and it had to be replaced about 500 bucks honda payed for it though and i wasnt even under warranty but since you tampered with the wiring i doubt they will if that is the case. and i guess you do know with that light on the air bacgs wont deploy.
Old Apr 9, 2006 | 07:45 PM
hhh711's Avatar
hhh711
Default yea
i no thats why i wanna get this thing resolved..i wonder if i can buy a diagnostic tools for the srs light
Old Apr 9, 2006 | 11:06 PM
bambbrose's Avatar
bambbrose
sounds like they could have damaged some of the wires going on the SRS wheel.
The srs wheel is the black and yellow wheel behind your steering wheel.. it has a ribbon of wires that goes down to a plug under the steering column, and then out to the srs control module, the srs gravity sensors, and that srs junk.
If the ribbon was damaged it would throw the code.
also your airbag could just be faulty, throwing the code, also the gravity sensors under the dash go bad on occasion as well.
Old Apr 10, 2006 | 05:43 AM
hhh711's Avatar
hhh711
Default me
well first off THEY didnt do anyhting if your tlaking about a person. it was me that messed with the wires. and it just went on so i odnt think the sterring wheel could bag could judt go bad. I wonder if i could get new gravity sensors though...
Old Apr 10, 2006 | 07:23 AM
hhh711's Avatar
hhh711
Default codes
Well since the light is on that means a code has been thrown correct...awsome so how to i check the code is it possible to to with the paper clip, like reseting it??
Old Apr 10, 2006 | 06:40 PM
Kai's Avatar
Kai
Rotorphile.
It's called the cable reel. It's very expensive and can easily be damaged if not properly replaced.
What year car?
Old Apr 10, 2006 | 07:13 PM
bambbrose's Avatar
bambbrose
What year car?
good to know the real name.. I just call it the srs wheel cause thats what comes to mind
