auto tranny question
Old Apr 6, 2006 | 07:20 AM
tommyhcky13's Avatar
tommyhcky13
Default auto tranny question
does the trans fluid go in the same place as the power steering fluid? because i took out the power steering and the tranny seems to be bumping into gear?
Old Apr 6, 2006 | 07:31 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
No. Check your trans fluid to see if its low or not. Power steering has nothing to do with trans fluid.
Old Apr 6, 2006 | 07:44 AM
what he said ^^^
what do u mean by bump? as in grinding whenever ur shifting or what?
Old Apr 6, 2006 | 07:51 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
Its an auto tranny so i think he means shid=fting real hard into gear not a smooth transfer.
Old Apr 6, 2006 | 08:44 PM
tommyhcky13
yeah it shifts hard into gear sometime, not all of the time. i couldnt find a tranny fluid tank and on my old car power steering and tranny fluid went in the same place.
Old Apr 6, 2006 | 08:59 PM
tafkamb2's Avatar
tafkamb2
theres a stick that says trans fluid like hidden behind the engine almost its kinda hard to find you have to get way down there to see it and if its shiftinf bad replace the filter that useually fixes the problem
Old Apr 6, 2006 | 09:17 PM
tommyhcky13
ok ill try that cause the filter has probably never been replaced
