Code 9 TDC Sensor
Rachel Bilson
Im posting here cause no one is ever in the Prelude forum....I've had this code for a while now...Replaced the distributor but still have this problem....Need some advice on how to fix this problem....Car will misfire sometimes...more often when the car is warm than cold...all i do is shut it off and start it back up again and it runs fine..sometimes takes more than one try..Any help would be appreciated
Rachel Bilson
Originally Posted by asheylarry
wiring problem? ecu problem? I have a few questions-- the code came back after you replaced the distributor? is it the original engine? let me know and i'll throw in my 2 cents.
are any of your connections butt-connected? im thinking that if its a new distributor and the code keeps coming back, then maybe(not too likely) you got a bad distributor (is it new or remaned? from honda?) or, you have bad wiring or ecu. is the wiring harness intact or have you spliced wires?
