reverse gear grinding
Originally Posted by JonD
there are no syncros in reverse
before you go into reverse, put it in first or third then go right into reverse, works all the time...
h: but technically it differs from car to car... some do
h:
Originally Posted by extensioncordy
mine grinds when im still rolling forward when i put it in. but if im at a dead stop or rolling back it goes in no grind
,instead of neutral to reverse!!!
Originally Posted by RicoD
WTF are u doing putting ur car in reverse while rolling?
i would be rolling slowly forward. then putting it into reverse with the clutch all the way in and it would give a slight grind i was wasnt rolling at a high rate of speed
Mine does this as well; I slightly disengage the clutch and let it grind a little, then try to go into reverse again and it'll work like a champ.
What's actually behind this though? (Hopefully something a new and improved clutch, next on my work list, will eliminate?)
