MAP Sensor
Old Mar 17, 2006 | 06:27 PM
koter18's Avatar
koter18
Default MAP Sensor
i hav a 96 RS n i need to locate my MAP(Manifold Absolute Pressure) Sensor, does anyone know where it'd be? or where i can find a diagram of it online?
Old Mar 17, 2006 | 07:53 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
There is a manual available for download in one of the stickeys in this section.
The MAP sensor is located on the throttle body. It has 3 wires going into it and connected via a round connector. It will be held onto the throttle body by 2 screws. Do not mistake this for the Throttle Position sensor as I believe they have the same wiring connectors. The throttle position sensor was located on the back of the throttle body, while the MAP sensor was on the top on my '97 GSR motor.
hih
Old Mar 17, 2006 | 08:36 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
hih
Exactly. The MAP sensor is on the top of the throttle body and the TPS sensor is toward the back on the side.
Old Mar 17, 2006 | 08:47 PM
koter18's Avatar
koter18
thanx
