F/S-F/T-180sx-REDTOP-HARDTOP-5LUG-ETC...
Looking to sell/trade for an S2000.
1991 Nissan 240sx Hatchback
191K on chassis
63K on motor, 13K on motor since installed
***THIS SR20 HAS COLD AIR CONDITIONING: RARE!***************************************
Gunmetal ext-Black/suede int
RARE HARDTOP w/ POWER EVERYTHING
EVERYTHING WORKS!
STRAIGHT FRAME, CLEAN TITLE
NEVER RACED ON ANY TRACK!!!!!!!!!!!!!
NEVER DRIFTED AT ANY DRIFT DAY!!!!!!
ULTIMATE SLEEPER
****ALL WORK PERFORMED BY IC-AUTOWORKS. ask Jspec.com or phase2motortrend, both had their cars worked on by IC-AUTOWORKS***
I have a set of Tanabe sway bars, F & R- brand new, not installed. they were supposed to replace the whitelines.Whiteline anti-sway bars
BNF20Z 27mm *Adjustable * Front Bar
BNR20X 20-22mm *Adjustable * Rear Bar
Rear Upper Control Arm Bushings (SPF1638K)
Rear Lower Control Arm Bushings (SPF1639K)
Rear Camber Correction Bushings (KCA347)
Rear Nissan Subframe Bushings (KCA349)
Front Lower Control Arm with SPF1009K Bushing pressed in.
SPF1202K TC Rod Bushings
Cusco Front Camber Plates
KYB AGX Shocks with Eibach Pro Kits Springs
Nismo Mechanical 2 way LSD kit
SUB-FRAME BUSHING SET #16 & #17 (55400-RS590--)
Cusco Strut Tower Bar Front Oval Shaft
Cusco Strut Tower Bar for Rear Aluminum Shaft
Cusco Front adjustable pillow mounts
Tomei 1.2mm Metal Head Gasket
ACT Street Clutch
Walbro Fuel Pump
Blitz 3" Stainless Downpipe
HKS Turbo Extension
180SX Cluster (7500RPM Redline/9000rpm tach)
Equal Length Manifold
Upgrade to R134 System
Custom AC Line
Toda Flywheel
Computer Upgrade
Nissan Gasket Set
Tomei Rocker Arm Stopper
HKS Blow Off Valve w/Recirculation
Blitz Down Pipe
S14 O2 Sensor
Steel Braded Oil Return
Steel Braded Slave Line
300ZX Slave Clutch
300ZX BRAKE UPGRADE
S14 5 LUG UPGRADE - FRONT AND REAR
** E BRAKE WORKS PERFECTLY!**
5zigen FN01R-C 17x8 all around
Extra set of S14 Stock rims
toyo proxes all around- 90% tread left
225/40/17 Michelin Pilot Sports all around- 60% tread left
Steel Braded Fuel Lines with Red covers
sr20det water pump
Chrome Nut Caps
Blow Off Valve weld Installed
3 Accessory Belts
Input Heater Hose
Output Heater Hose
NGK Iridium Plugs
Nismo Thermostat
Blitz Front Mount Intercooler
Optima Red Top Battery
*BATTERY RELOCATED TO REAR*
Greddy Oil Catch Tank
Clifford Alarm
Sony CD/MP3 headunit
Alpine V12 amp
Infiniti kappa speakers (4)
300ZX Clutch Master
Blitz 3" Exhaust
HKS 42mm Oil Pressure Gauge
Crank Angle Sensor
HKS Boost Gauge
52mm HKS Holder
S14 cloth seats installed!
S14 seatbelts installed!
JDM 180sx tail lights installed
***the trunk key has been re-keyed to be used by the original key***
PICTURES ARE AVAILABLE @ http://ziff.net/~danny/240sx
PLEASE MAKE ME AN OFFER!!!!!!!!!!!. please feel free to contact me anytime-626-831-2181. I am located in the so. cal area.
191K on chassis
EVERYTHING WORKS!
ULTIMATE SLEEPER
ACT Street Clutch
Walbro Fuel Pump
HKS Turbo Extension
Custom AC Line
Toda Flywheel
Computer Upgrade
Nissan Gasket Set
Blitz Down Pipe
S14 O2 Sensor
300ZX Slave Clutch
300ZX BRAKE UPGRADE
sr20det water pump
Chrome Nut Caps
3 Accessory Belts
Input Heater Hose
Output Heater Hose
NGK Iridium Plugs
Nismo Thermostat
Clifford Alarm
Alpine V12 amp
300ZX Clutch Master
Blitz 3" Exhaust
Crank Angle Sensor
HKS Boost Gauge
52mm HKS Holder
