power antenna switch?
Old Mar 11, 2006 | 10:23 AM
Robobeaver's Avatar
Robobeaver
Default power antenna switch?
I drive a 94 ls. it has a power antenna, and i hate it. I never listen to the radio, so i really dont need it. It goes up when i turn the car on. i would like to install a switch to manually put the antenna up.
I would really appreciate it if anyone could tell me how to install a switch, where the wire that runs to the antenna is, or point me to a walk through. I dont know much about the wiring so if you could, be pretty specific.
thanks everyone.
Old Mar 11, 2006 | 11:25 AM
JRsONE's Avatar
JRsONE
Thats a good one I have the same issue, I got a 95 teg does anyone know where and what wire to cut, to stop that stupid antenna from going up??? Eventually when I get enough money for good paint job Im just gonna have them shave the antenna off at the same time...
Old Mar 11, 2006 | 11:53 AM
torn_phoenix's Avatar
torn_phoenix
you would
http://www.team-integra.net/sections...p?ArticleID=74
This is the diagram. The wire runs down the driver side under the panel in the door area. It's relatively easy to get to. Just make sure you get the right wire. ;-P
Old Mar 11, 2006 | 02:18 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
or if you have an aftermarket stereo ... (it's the lighter of the 2 blue wires) should have something along the lines of "antenna pwr" on it.. cut that... and just splice a power switch into it
Old Mar 11, 2006 | 02:49 PM
Robobeaver's Avatar
Robobeaver
is this the right wire. this is up under the dash, right next to the fuses. also is there a better place than this to splice the switch under the dash?
File Type: jpg
Old Aug 17, 2006 | 05:53 PM
Integra94LS's Avatar
Integra94LS
i just bought a switch to do this with my antenna..where is the best spot to splice the where and mount the switch?
Old Aug 17, 2006 | 08:31 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
That looks like the right wire. Without consulting my Helms manual, I am not for certain. I spliced mine at the radio harness since I have an aftermarket head unit.
Old Aug 17, 2006 | 08:55 PM
bnuk's Avatar
bnuk
uhhhhh isn't that his fuel system relay??!
just look behind your stereo, you will want to mount the switch in the the liitle knock-out squares in the console anyway.
Old Aug 17, 2006 | 10:28 PM
sk8ps's Avatar
sk8ps
Test it before splicing! Grab a multi-meter, test it with the radio off (antenna down).... Should rest at 0V. Turn the radio on, if it switches to 12v its your acc, ign or antenna....try turning the radio back off and jumping an alternative 12v source (i.e. white wire in ignition harness) to it w/ the radio off. If the antenna goes up, your golden.
If not, do it the easy way... grab it directly from the back of the radio.
Old Aug 18, 2006 | 12:56 AM
96BLKGSR's Avatar
96BLKGSR
That is the wire that goes to the fuel pump (which happens to also be yellow with a green strip). The attenna wire shouldn't be coming out of the main relay.
