inexpensive buffer
Old Mar 10, 2006 | 05:36 PM
koter18's Avatar
koter18
Default inexpensive buffer
i know that PC 7424 is the most recommended buffer out there but i can't afford that
so i found this Coleman Powermate 10" Random Orbital Waxer/Polisher at Autozone for 30 bucks
Should I get this? or because its cheap, is it REALLY going to mess up my paint?
Old Mar 10, 2006 | 08:35 PM
TypeG's Avatar
TypeG
it probably won't mess up your paint, it just won't have enough ummph to do a good job. later.
Old Mar 10, 2006 | 08:45 PM
koter18's Avatar
koter18
isn't 3200rpm(orbit/min) enough? what rpm do i need?
Old Mar 11, 2006 | 02:37 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
i wish i could help you out more... but im pretty sure the regulars over in the appearance forum would know a good bit more about this than the regulars in the integra forum.... good luck
Old Mar 13, 2006 | 01:22 PM
kiddcarbuff's Avatar
kiddcarbuff
dont use a shitty buffer on your car, it has trhe possibility to burn thru ur pain if u can buff for crap. invest in a good buffer(i.e. makita ) it'll make your life a whole lot easier
Old Mar 13, 2006 | 01:56 PM
jokeintegra's Avatar
jokeintegra
yeah you get what you pay for. Milwaukee makes a good buffer as well. Also use 3M compounds. They come in a variety of abrassives!
Old Mar 14, 2006 | 05:42 AM
reno96teg's Avatar
do you really want to skimp on the most important cosmetic feature of your car?
the porter-cable is an excellent option, with great results. you can get the porter-cable 7336 for about $100 even, i think, from Lowe's, and it's the same as the 7424. (it comes with a pad, but you'll want to look into buying more appropriate ones)
i think it's well worth the price, and come on, is $100 really that much? i don't think so. a $30 autozone buffer is likely going to cause you more headaches than the $70 savings is worth.
my results with the PC 7336: https://www.honda-acura.net/forums/s...d.php?t=202833
i'm not saying you have to absolutely go with the PC, but do your research, and don't skimp.
