must i replace this?!?!?!
Old Mar 4, 2006 | 05:02 PM
rugsr's Avatar
rugsr
How do my taillights look
Default must i replace this?!?!?!
ok so im cranking down on the bolts that are holding own the piece of metal that is above the cam. like a cam cover. bolts are 12mm nd black. well the bolt that is all the way on the pass side exhaust cam snapped. i was using my torque wrench and I GUESS IT DIDNT WORK. any way must i replace that bolt
heres a pic. if you dont know which bolt i mean let me know ill point it out better
Old Mar 4, 2006 | 05:16 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I would. It won't kill your motor, but it is wise to replace it.
Do you need a part number?
Old Mar 4, 2006 | 05:26 PM
rugsr's Avatar
rugsr
well im boosting it and the motor will be under pressure, but not here. the thing is im 0 for 2 with a drill out. so i really dont feel like trying again. i just dont wanna put everything back on. hit full boost and something go cuz of that. that area is near the cam seal which i just replaced(thats why it was off) so im wondering if oil can get through there. but it still seems very tight.
Part# for the bolt? if there is one, sure.
Old Mar 4, 2006 | 05:32 PM
Provocateur
On permanent hiatus
So the bolt is completely broken off without anything to grab onto with vice grips?
The part number is 95701-08050-00. $.88 a pop at acuraparts247.
Old Mar 4, 2006 | 05:50 PM
1turbodc2's Avatar
1turbodc2
got boost?
that is scary u know that!
Old Mar 4, 2006 | 09:09 PM
rugsr's Avatar
rugsr
bolt is in half. half in my hand.......half is in the motor!
Old Mar 4, 2006 | 10:02 PM
Provocateur
On permanent hiatus
That really isn't a good thing. Have you tried using a bolt out tool instead of drilling?
Old Mar 5, 2006 | 03:05 AM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
it should have a 10mm nut casted into the bottom.
Old Mar 5, 2006 | 12:15 PM
rugsr's Avatar
rugsr
bolt out tool? explain yo self
not sure if there is a nut cast into place. are you talking about a nut into the motor?
BTW it should be tightened down to 20ft/lbs right?
Old Mar 5, 2006 | 04:19 PM
rugsr's Avatar
rugsr
TQ anyone?
